petem
This is the sort of programmable ECU that you need I reckon....But it might also transmit something to tell vodia what it's doing.
Diesel ECU for VP37 EDC fuelpump | ecushop
I believe that Bosch make the fuel injection pumps etc for all the KAD AND TAMD engines. The KAD engines use a cheaper to make and smaller rotary injection pump. The TAMDs use an inline injection pump. However they are both controlled in essentially the same way.Thats all very good for you Bosch boys what about us poor TAMD owners
Thanks Kashhurst ?I believe that Bosch make the fuel injection pumps etc for all the KAD AND TAMD engines. The KAD engines use a cheaper to make and smaller rotary injection pump. The TAMDs use an inline injection pump. However they are both controlled in essentially the same way.
The ECU provides a pulse width modulated output to the injection pump solenoid that physically moves the spill ring (KAD) or spill rack (TAMD). Inside the pump is an inductive sensor to measure the movement of that rack so the ECU has closed loop control (i..e. safe)
The MAP sensor (air pressure sensor) is in the Volvo ECU. Easy to fit another one (and he sells them) into the existing engine manifold via an adaptor.
I haven't written any serious software for a loooong time . The last time I wrote anything of any complexity it was in assembler and visual C. - I was hoping you would volunteer?good, so you sorted it, now K buys one and on next lockdown sorts out the s/w for it
I agree, it would appear to be capable of running the engine. I'm not sure it has all of the KAD sensors (e.g. fuel temperature) but you could probably live without some of these (as I think you are at the moment!).Well done Pete, I think you have found the solution.
DSL1
That ECU looks like it can do all the required functions to run a Volvo EDC/bosch engine. It would need software to understand the throttles as the same potentiometer is used for forwards and reverse. So it would need a calibrate function and a method to select which throttles you wanted to use.
There are spare programmable outputs for the gearbox solenoids and a supercharger too.
If I was waiting for a new Volvo ECU for my boat I would be on the phone now.
Baldur is in Iceland - pretty sure he will know someone with a boat.
I think Volvo Penta need to come clean with their ACTUAL intention. Either they are doing their best to get them made with all the difficulties with supply etc at the moment, or, they have NO intention of manufacturing more , and if not, will they be helpfull in letting a 3rd party copy them .Maybe a few emails to Hel'ene Mellquist will encourage some info. Unless they are using the "head in the sand" principle hoping that this PR problem will go away.
Perhaps if every single interested party wrote to her, she would get the message.
Is there any way to bring this to wider media attention by writing letters to be published in all the boating journals ?
Does someone have her direct email address.Perhaps if every single interested party wrote to her, she would get the message.
