Volvo Saildrive, Which Antifoul
Ribtecer
23 Aug 2006
What the title says really, what is the best/correct antifoul to put on a Volvo sail drive unit please?
Many thanks
VicS
13 Jul 2002
Many thanks
As above but you can use any antifouling which is suitable for use on aluminium. These usually contain copper(I) thiocyanate rather than copper(I) oxide.
It is convenient to use a spray can
If Jotun antifouling is your preference then use Aqualine spray.
johnphilip
15 Nov 2005
It depends which colour of barnacle food you want to offer the persistant little B..............
I have tried several receipes on my prop & leg and none seem effective. Worse last year, I think that was because the boat was not used often enough.
Tranona
10 Nov 2007
If the saildrive housing has its original coating on it then use the primer for the spray can - International or Hempel both have a dedicated primer.
NBs
9 Nov 2017
Hi,
aluminum boat antifouling paint, Hempels alusafe, other manufacturers also have products. Anything copper based is not good.
NBs
stuartwineberg
24 Oct 2007
Romsey, Hants
Trilux. However I think it has been discontinued, that said I had no problem getting it online. Sml paints (the jotun people) have their version in a slightly smaller rattle can
ss2016
24 Jul 2016
All done with a rattle can of Trilux Prop-0-Drev.
Many thanks to all.
How did the Prop-O-Drev do? Would you recommend it? I used Hempel Ecopower but it was pretty much useless. The Prop-o-Drev contains copper thiocyanate which is a biocide and presumably the copper is in a form that does NOT react with aluminium. Anyone know more? It comes in a spray can which on an outdrive is pretty much essential.
Neeves
20 Nov 2011
Sydney, Australia.
Velox or Prop Speed. There is a competitor to Prop Speed, variously called Prop Gold and Prop One. From memory the active ingredient in Velox was the same as Trilux, but in a different concentration.
None of these are particularly cheap, all require following the instructions - exactly.
They all require you to use your vessel frequently - they rely on the fouling not having time to gain a tenacious hold.
If you use a silicone based concoction and you find it does not work as well as you had hoped then you need to ensure you remove all the silicone coating - as nothing will stick to it (excepting more fouling). I think Prop Speed sells a product to aid cleaning.
Once your prop, or sail drive, starts to collect fouling you are on a slippery slope - scraping removes the fouling but also the protective coating. A silicone coating is particularly soft.
Jonathan
Baddox
1 Mar 2010
Sunny Northumberland
Seajet 034 is much better than trilux, straight forward to paint on, I wouldn't say a spray can is essential in my experience.
That's what we have used for the last 8 years and been happy with it. It contains a 2-part primer that seals the surface and then the AF goes on top. The spray-on antifouls give a flatter, smoother finish which you may prefer for the propeller but they don't seem as durable.
