MartynJS
Over the years I have always inspected and/or changed the oil in my 290E DP leg. Very often there was water in the oil; not much, but enough to make the oil 'milky'. So last year I spent a lot of time trying to establish where it was getting in. I carried out pressure and vacuum tests on the leg and applied oil to the various seals until I found the culprit; the vent plug close to the top of the leg , facing astern. This badly designed plug is sealed with a simple fibre washer. This has a large enough internal diameter to clear the threads on the plug but, unfortunately, the plug has an undercut below the head. This prevents the washer from centering and allows the inner diameter to settle very close to the edge of the head of the plug. Any distortion on tightening and 'hey presto', it leaks.
I would be interested to hear whether anyone else has had similar problems. I got over mine by fitting a Dowty seal in place of the fibre washer and this year the oil was clear. Anyone else had this problem?
