geem
I rate my Spade anchor higher than a Rocna of the same weight. I think it sets more easily here in the Caribbean.Most anchor manufacturers recommend sizing tables that assume the boat is never going to experience anything more than moderately strong winds or poor substrates. This helps sell anchors.
If a manufacturer recommends a smaller anchor, it must be better.
This strategy of recommending small anchors particularly helps anchor manufacturers sell to boatbuilders. For a boatbuilder fitting a small anchor as standard equipment means a smaller anchor winch, bowsprit, etc., affording considerable savings. If the customer complains, the boatbuilder can correctly claim they are fitting the anchor manufacturers recommended size.
Some anchor manufacturers are honest and state the maximum windspeed their sizing is based on. This can be as low as 30 knots. Many others don’t state the criteria (which suggests to me it is low).
I cannot understand why some members of this forum recommend blindly following these recommendations. Or even worse council against installing anchors with more holding ability.
Rocna uses a slightly more realistic 50 knots as a "soft moderate holding bottom" and assumes you have the room to provide reasonable scope. If you anchor frequently, it is not uncommon to exceed these requirements, but it is at least a better starting point if you cannot comfortably manage something with more capability.
Since we don't see boats with well set anchors dragging in 50kt squalls, what does that tell you about the holding capacity of the older anchors such as Bruce, CQR and Delta? May be they are adequate for their intended use? Then you apply the well proven data that NG anchors have twice the holding power of such anchors.
If the old generation anchors can easily stay put in 50kts, I suspect any NG anchor is going to have no problem in substantially more wind, even sized correctly for the boat weight and windage.
