PaulRainbow
Don't think you should use the one from #12 in a boat:Post 12 shows what I see others on YT fit instead of the supplied version.
The transom locker is intended mounting area ... not sure about how well sealed off from aft under cockpit bunk area ....
Looks reasonably closed off ....
Same other side.
"The upgraded silencer has two small holes on one side. The two holes are for drainage. The side with the holes needs to be installed underneath. When venting, water vapour is sometimes produced and condensed water will drain through both holes.
It is recommended to be Installed at outdoor."
If you use the Planar silencer it is fully welded with no drain holes and is less than half the price of the Eber/WEbasto ones, at £31
