You need to dream of better velcro
Stuff I was given is used, amongst many applications, to secure modules inside million dollar gyro stabilised cameras on helicopters. Crazy strong and will never have a nut rattle loose![]()
Intresting though process , but you do know a vertical fighter plane will pull around 9 G and the normal human can handle around 5 G
I think the G force of an object placed on a bulkhead has very little G force on it , a typical jet taking of you feel around 1.5 G
And F1 pulling around maximum 4.5 G
So if your Boat sails down a large wave pulling heavy G you will not care about your Velcro more your underpants![]()
Yes 10G sounded unlikely.
The difference with something like a boat is the force will be momentary.
I'd think it obvious a boat will sustain pretty severe momentary G shock loads when battering into waves or falling into troughs, hence why things which seem well stowed end up on the cabin sole.
Also when working on the foredeck it's not unusual to have the deck drop from under one, so negative G at the front, momentarily.
It would be interesting to fit accelerometers on a typical cruising boat in heavy weather or going through overfalls, I'm sure plenty of designers have such data to hand.
I don't know what definition that is ...QUOTE]
The definition that when one free falls under gravity one experiences negative 1G.
Richard
Richard
If you are falling at 1G but the hull is now rising up a wave is there not a moment when those two multiply/add/combine in some way...?
Indeed .... but that's not the falling into the trough or the deck dropping away. That's when the falling/dropping stops. But it's not much of a fall and it's usually a reasonably watery stop so I suspect that large G's will be very rare.
Richard
Can a boat really ever experience more than 1G? I suspect that anything more is extremely rare.
Richard
Every time the bow raises on a wave or stops sinking off another it experiences more than 1g. Every time it stops raising and starts falling it experiences less than 1g. If you've ever been bounced on the foredeck you have experienced more than 1g and momentarily less than 1g. A falling object accelerates until it's drag equals it's mass*1g. It is then in equilibrium and no longer accelerating. The g you would "feel" starts at 0 and increases to 1.
-1g would require some other outside force to to accelerate you faster than gravity, like a wing or the rails of a rollercoaster but you cannot free fall at -1g. You free fall at 1 g and feel 0 to 1g as your acceleration rate reduces to 0. When you hit the ground you will experience considerably more as your velocity reduces to zero rather abruptly.
http://finot.com/nouvelles/actucourse/0301recherche/csys4.pdfSo what do you think .... max say 1.5G or max say 10G?
Richard
This one?That was the maximum single recorded high on one racing boat in 5m waves out of all those tested on one occasion right at the bow.
1.5G was the usual maximum and that amongst large ocean going racing boats in severe conditions.
I refer to my original hypothesis.
Richard
Which is patently incorrect.The definition that when one free falls under gravity one experiences negative 1G
This one?
Which is not correct. A boat will probably experience more than 1g about 50% of the time. The other 50% being less than 1g.
Absolute tosh, I'm afraid. A sailing boat will experience about a fraction over 1G 49% of the time and a fraction under 1G the other 49% of the time. During the other 2% it will experience slight more with a typical maximum of 1.5G and, extremely occasionally, for a racing boat in storm conditions at the bow, up to 5G. However, a cruising sailor will probably never experience 5G in his or her entire life, and 10G is totally impossible.
I refer you to my original hypothesis. :encouragement:
Richard
