winsbury
since we don't use shore power I was surprised when lifting our outboard from the well which has been in the water for 4 months after fitting a new anode to find its virtually gone. Is this normal ?
i am haveing problems with electrolysis how can check where power leak starts
my boat is a pegasus 26 ft bilge keel problem started last year the bilges where badley eating away at end of season i sanded all down re painted and fitted anodes to both keels this year both anodes were badley corroded as were the bilges there is big flakes of corroded metal roughley 1/8 off a inch deep x 2 inch diameter. the anode on the sail drive is not touched first time on forum did not no to start thread
Answers to VicS' questions will help a lot. Additionally, are you in 'pure' seawater or is the berth in fresh/brackish water?
i have my own mooring in sea water in donegal there is no connections to bilges the bilge bolts seem rusty on starboard side i am going to take bilge off this winter to repair i fitted a new engine 4years ago its a beta 15 hp the anode on the engine was wasted away i replaced it the start off year when i last checked it 6 weeks ago it was ok i have been turning of the battery power half way through season its hard to tell i think the problem has not been as bad there is no shore power i did sand bilges down to years ago and painted them with red lead then antifoul them i not sure if that makes a differance thanks mean time
Pegasus keel bolts should be sealed in epoxy so impossible to examine...if someone has replaced them its important mild steel and not stainless are used as the dissimilar metals will corrode and the stainless will also suffer crevice corrosion when re-epoxied.
