Value for Money
Why don't you just dry out against the quay or piles? - or don't you have such things in the solent?
<hr width=100% size=1>dickh
I'd rather be sailing... :-) /forums/images/icons/smile.gif
Re: In an attempt to be serious .....
Don't worry Mike, I am more than aware of the cost of lifting out and laying up - I've been surviving on cheese and water in order to pay our own bill!
I was just thinking that our friend could get more value for his money by lifting out for a while and getting all necessary tasks done for one price.
This would also mean he could work on the rudder in more relaxed timescales.
(Or in your terms - a bit like fitting a new steering assembly in a factory workshop instead of a service area in the middle of Wales!)
<hr width=100% size=1>I'm average size, Its just that everybody else is short.
Much easier in the middle of a Welsh Forest probably!! "Prophecy" comes out for a couple of weeks for antifoul and the fitting of a bowthruster at the end of March, so I'll be hit with a pretty heavy 'lift/block/relaunch' bill myself!!
"BOWTHRUSTER?, what the hell do you want one of those goddamned things for!!"
OK, OK,have a go, and get it over with!! Trouble is have you seen then size of Nigels' Southerly 135 just across from my transom?? It was tight enough before. I just don't want to be around when they cut a damned great hole in the hull!
Gosport boat yard, quite close to Para come to think of it, was offering a rate of £2.50 per foot, which included washing down with a pressure washer. (the boat that is not you, oh well maybe you too). Might be worth a look.
<hr width=100% size=1>Fill
Agree with Gosport Boatyard - they gave the best rates when I hauled Amaya out for a survey, and very helpful too.
Problem is I need to get lifted high enough to drop the rudder stock out. If i just dry out I cant .. also I beleive the adhesive needs 24hours to go off
<hr width=100% size=1>.. whit way roon should it be again ..
Re: Get yersel back doon ...
He is going bald!!
Who's the young diver he's roped into holding Douglas underwater? are you available for rubber wear evenings?
<hr width=100% size=1>Utinam logica falsa tuam philisophiam totam suffodiant
Yes, and from personal experience I can assure Jimi that from the state of lack of hairyness he has reached it is all downhill from there. I am sure that it is being exposed to too much antifouling that does it.
John
I thought it was lack of ozone layer in the southern hemisphere that made you all hairless and webfingered
I take it back, it's antifoul and inbreeding
