V/P 290 outdrive
Dean
10 Oct 2002
Leicestershire
What i'm after is the location of the little triangle anodes on the outdrive.
Mine was not fitted as standard but i have bought some but don't know where they go, other than on the H bracket.
Any offers?????
Dean
As you stated its not stated, but to fit one you need to drill a 4.5mm hole and tap it to 6mm in the web of metal in the H bracket frame on the starboard side of the leg. You will see that a vertical strut comes down from the pivot point and then it has a cross piece that supports the gearbox center section. It sits just in the angle of the web with the long side of the triangle running from 9 o'clock to 12 o'clock if this make sense. Just check on the bolt thread size as its a few years since I fitted one so this is from memory.
regards Steve
<P ID="edit"><FONT SIZE=-1>Edited by spannerman on 16/02/2003 20:16 (server time).</FONT></P>
