Poignard
What do you think?
My engine is a BUKH DV10, in case that makes any difference.
It does what is says on the tin. I don't think it is as necessary today as it was 30 or 40 years ago when tolerances on engines were not as good and fuel additives were not used. Although with the removal of lead.....
But when did you last hear a car engine pink
My dad always bought an extra squirt of UCL when he filled up in the 'old' days
Regards
Donald
When I first joined the research company of a major oil company I was working in a laboratory next door to a man who assessed every product that was supposed to improve upon the standard fuel or lubricant's properties. This was a full time job for him as in those days there were hundreds of them, often featured in news documentaries and suchlike with the assertion that the oil companies were going to buy the company and shut it down as the effect upon their sales was going to be so drastic. Many of these were UCL types such as Redex, Slick 500, STP etc. As ever with the company the job was done properly, using test cars that would be assessed internally before and after the tests. All gasoline engines as far as I know. In some cases the products reacted with additives in the lubricant and had a harmful effect.
He told me that he only ever found one product that made any positive difference, although in a modest way. That was a small fitting that held a metal gauze across the inlet between the carburettor and manifold, supposed to improve 'atomisation' of the incoming fuel mixture. It seems this thing did improve economy at low revs but was quite a restriction at higher throttle openings, which impacted quite severely on top speed.
Those days are long gone, unfortunately, and the research centre along with them.
But when did you last hear a car engine pink![]()
What do you think?
... There was also a gadget that sprayed a water mist into the carburettor that was supposed to work wonders. It also seems to have never come to anything. ...
I put 1/4 tank of petrol in my diesel car then realised what I had done. I filled up with 3 l if engine oil and the rest diesel. The car did another 100000 miles with no probs. So the previous point about adding lube to diesel may have merit
Not for UCL but worth adding a little 2 stroke oil (500:1) to diesel to provide lubrication in the fuel system; lubrication which many believe is lacking in modern low sulphur diesel fuel especially if road diesel is used.
A diesel engine will burn anything that can go through the pump and injectors! Simplistically speaking, engine oil is just thicker fuel oil! A hydrocarbon is a hydrocarbon!Adding engine oil to fuel is not recommended as unlike 2 stroke oil it does not readily burn and leaves a residue.
Used to be popular in olden times. Anyone remember the conical squirty cans of Redex at petrol stations?
Yes. When I were but a slip of a lad around 1970 I worked on a garage forecourt serving fuel. 2 star was 32p/gallon - 3 star 34p - 4 star 35p - and 5 star a whopping 36p! (ish). Each squirt of Redex was 1p extra unless you regularly gave me a tip, in which case I would let you off.
Read more at http://www.ybw.com/forums/showthrea...using-or-just-a-con/page2#r50gSlo7DOmFoUUX.99
+1 - I remember the forecourt Redex 'squirter' and my last memory of such was a bit before that when petrol was 6sh. and 8p per gallon ( or 8p per litre equivalent)- which roughly converts to 33-34p per gallon![]()
