Kukri
After her sea trials...the QE sailed around the world. All will be fixed...it always is
Sailed around the world once, (?) in five years. These things should not need fixing. ?
£3million per ship seems incredibly small. Are you sure? Do you mean billion?On such complex projects there will always be teething problems; the French Navy had all sorts of problems with the Charles de Gaulle at the outset, particularly the screws which broke up and had to be replaced with the old ones off the Clemenceau. Many people in France put this down to bad luck caused by the name change (at the outset she was to have been the Richelieu, but Chirac had the name changed to CDG).
FWIW, she cost over €3 billion back in the 1990s. The reported cost of the QE and the POW is £3 million each, so I guess that’s not too bad (though the Charles de Gaulle is Nuclear).
I fondly remember the delight in our MEO's eyes when he was allowed to flash up the Olympus turbines rather than stooging around at 10 knots on the Tynes! The chap on the left:The French can afford to send their nuclear CdG to sea. One of the reasons why our Navy (submarines excepted) is almost always in port is that we can’t afford the fuel for them,
One of the problems of nuclear power in ships is refueling....although it might only be once in the ship’s lifetime...it can take a year. To be effective you need a minimum of two carriers so at least one is close to being available at any time. The French only have the one carrier...and when she is replaced by PANG (Porte-avions de nouvelle génération)...a nuclear powered super carrier..it will still only have the one.The French can afford to send their nuclear CdG to sea. One of the reasons why our Navy (submarines excepted) is almost always in port is that we can’t afford the fuel for them,
I happened to drive past Rosyth this very evening and noticed the gantry crane is still there - but it's now got 'Babcock' written on itThe gantry crane used to build the two carriers was indeed made in China by ZPMC and dismantled and taken back to China when they were finished. We don’t know how to make them, here.
...Almost every ship in the world has a propeller shaft or sometimes two.
It's not disabled; they aren't using one shaft as it's leaking. Both will work if needed. Every propellor driven ship in the world could have their stern seal compromised by mechanical damage from grit, fishing line, rope etc. It's a mundane fact of marine engineering.Aircraft carrier can be disabled by a fishing line or rope. And you don't consider that to be poor design?
That was a leaking firemain; poor QC maybe, nothing to do with design.Which pearl of wisdom - "poor design" or the shaft leak?
HMS Queen Elizabeth: Water leak on aircraft carrier 'neck-high'
Is that the definitive problem...a shaft seal?It's not disabled; they aren't using one shaft as it's leaking. Both will work if needed. Every propellor driven ship in the world could have their stern seal compromised by mechanical damage from grit, fishing line, rope etc. It's a mundane fact of marine engineering.
MoD aren't saying.Is that the definitive problem...a shaft seal?
One of Wilbur Smiths books (IIRC Hungry as the Sea) a large tanker has a bearing problem and the spare bearing's diameter for the shaft that was aboard was made to imperial dimensions and the shaft to metric dimensions, but one or the other was rounded of and the upshot was that the replacement bearing was as useless as if it have been 6" smaller or even 150mm larger.
Of course, a typo. Now corrected, thank you.£3million per ship seems incredibly small. Are you sure? Do you mean billion?
I remember reading that book - a good tale, but some facts are a bit off.
They mention how the tug has 2 x 22,000 hp Mirlees engines in her - if she actually had this much power, I don't think they would have much room for anything else, as the whole vessel would then be full of engine room and fuel tanks.....
Of course, an aircraft carrier is the ideal platform for relief operations, for all of the reasons listed above.Reminded me of this:
"There was a conference in France where a number of international engineers were taking part, including French and American.
During a break, one of the French engineers came back into the room saying, "Have you heard the latest dumb stunt Bush has done? He has sent an aircraft carrier to Indonesia to help the tsunami victims.
What does he intend to do, bomb them?"
A Boeing engineer stood up and replied quietly:
"Our carriers have three hospitals on board that can treat several hundred people; they are nuclear powered and can supply emergency electrical power to shore facilities; they have three cafeterias with the capacity to feed 3,000 people three meals a day, they can produce several thousand gallons of fresh water from sea water each day, and they carry half a dozen helicopters for use in transporting victims and injured to and from their flight deck.
We have eleven such ships; how many does France have?"
You could have heard a pin drop."
Seems according to Bouba - Apparently only one.
