ProDave
As I discussed before, to match the towball height with the trailer height, I had to use a drop plate "upside down" to raise my towball. In fact I regularly drive my car with two towballs of different heights fitted. but then my car IS 4X4 so I have no concerns about that.Oh yes. I read that as 100lbs.
With regard to adjustable height couplings, the e-marking situation usually means that only a 4x4 can legally have an adjustable coupling height, unless you particular car has an homologated one available.
My boat trailer is like that, just the front axle braked. But since the trailer is probably as old as the boat, if not older, i.e 1980's I have always assumed if it was legal when it was built, it is still legal to use. In much the same way that my 40 year old Landrover with single circuit brakes, no foglights etc etc is still perfectly legal to use.Also a lot of older close-coupled trailers only have the brakes on the front pair of wheels which is not legal now. I haven't worked out if that new regulation is backwards enforceable.
Giving another example for the OP, my 18ft boat weighs about 750Kg and the trailer no more than 500Kg so I'm comfortably below the towing limit of my car of 1500Kg
And nose weight is very important. My trailer when I bought the boat was set up completely wrong with no nosewight and it towed like a pig. I had to move the axles back a bit to get some noseweight and now it is stable to tow at 60mph.
My own trailer also had 2 rotten tyres and 2 near failed wheel bearings when I got it. It survived a 25 mile tow home slowly, but had I taken it straight on a long motorway journey I am 100% sure it would have ended in failure. If you are going to collect a boat on a trailer and tow it a long distance you are placing 100% faith in the previous owner setting it up and maintaining it.
