Kukri
Want to change a halyard winch. The bolts seem to have been put in with some white rubber stuff which is horribly tenacious. Got two out; three more won’t move...
What type of bolts (screws) are they?
Hi Johnathan,
It’s a Harken 44:2 on the mast. To be precise, the main halyard winch. It’s a non self tailer and I’m wanting to swap it for a 44:2 self tailer. The two bolts that have come out seem to be in what may very well be white Sikaflex; they don’t show any sign of interaction with the aluminium, but they were swines to get out.
Thanks for the tip on using heat.
I had 4 2" BSP plugs fitted to my sea chest arrangement with white sikaflex and when I came to remove then I had to use a 3/4 " breaker bar with 3 socket extensions and a 2 meter tube shifted with all my 83 Kg weight standing on the end.
Sikaflex in screw threads can be very difficult to remove.
Mmmmm!
I'm in the process of making up sight glass fuel gauges for my diesel fuel tanks. I need a sealant for the glass tubes so I was thinking of using Sikaflex but I read that Sikaflex was not suitable for fuels.
Maybe some diesel might soften up the Sikaflex?
I am astonished that any PU sealant has sufficient strength to combat loosening bolts. I would have thought the problem is more to do with stainless into aluminium, which is notorious for corroding into an unmovable mass. Galling certainly occurs stainless to stainless, I have had a couple of experiences with turnbuckles that were absolutely solid. Is there any possibility that Loctite has been used? The top grades of this product need serious heat to release their grip.
When asked about siezed stuff, I always say there is no guaranteed answer. A combination of oils, including snake oils! heating, tapping, brute force, swearing will usually get you there!Vyv
I have an Edson steering wheel set up , with the compass set in a housing above the wheel spindle. The housing is white powder-coated aluminum (sp USA?) and about six inches high. Several long s/s bolts hold it down to the rest of the steering binnacle, which is also aluminum. These bolts are now very stuck and I really need to lift the housing off to service the steering.
Is heat the only answer? How best to apply it?
Or should I just order a complete new assembly?
Peter
