bendyone
Tru design say its fine but a suveyer has said not recommended. Any views?
Ask the surveyor to back up what they're saying with some evidence. They ought to be able to show you some regulations or documentation to explain their spurious claims.Tru design say its fine but a suveyer has said not recommended. Any views?
Or, possibly more importantly, the hose connecting the cock to the engine/strainer.What is your hull made of?
He is saying "not recommended" - not "can not be used"Ask the surveyor to back up what they're saying with some evidence. They ought to be able to show you some regulations or documentation to explain their spurious claims.
He can say whatever he likes, but will need to justify such statements with some kind of evidence otherwise TruDesign would have very good grounds for action against him.He is saying "not recommended" - not "can not be used"
Who is making the recommendation, the surveyor or a significant body of evidence? If a significant body of evidence he will be able to able to give you multiple references.He is saying "not recommended" - not "can not be used"
No. Nylon has excellent resistance to hydrocarbons, it is used for gasoline in many applications. Glass reinforcement offers superb resistance to thermal fatigue and embrittlement.You are all peering down the wrong end of the telescope.
Could it be chemicals often leaked out in the ER ( fuel , old oil etc as examples but not limited ) might degrade the nylon latently ? Or repeated heat cycles over the years results in embrittlement ?
Its more likely that because the person fitting them thinks it’s fit n forget .Parked the whole sea cock problem .
While trad metals have certainly inspection and change out regimes are better at resisting ER leaks and heat cycles and of course folks inadvertently standing on them or dropping eg a battery on them !
I have the Forespar marelon glass reinforced versions. They are bulky but very strong and stable. I can see on some applications there would not be space to locate them. Also, they only do them with hose tails. No other option. By comparison, the trudesign valves look vulnerable. I am sure they are not but they are quite a lot slimmerNo. Nylon has excellent resistance to hydrocarbons, it is used for gasoline in many applications. Glass reinforcement offers superb resistance to thermal fatigue and embrittlement.
There is essentially no real difference between plastic and metal seacock strength or chem resistance (as a metallurgist it pains me to say this!). The only problem is that the wall thickness is increased to match the strength, making them more bulky.
Which ones, specifically what did they say?I'm going back a bit, but insurance companies said no, is this still the case?
My understanding is that nylon is a thermoplastic....... not a thermosetGlass-filled nylon. Thermo-set, so will not melt. If these melt, so will your hull. The hoses will go long before.
