Torqeedo real world experience
blxm
18 Aug 2014
Took the plunge and decided to purchase a Torqeedo 1003 recently. There has been much debate over electric outboards and therefore was difficult to make up my mind as to the pros and cons of these things, a lot of comment ( I now realise a lot is I'll informed) but little in the way independent user experience. So I thought I would provide some of my experiences to help others in determining if a Torqeedo is the way to go.
The most obvious concern is range. OK, the electric will never compete in that respect. I was initially concerned over this and put me off for some time. Previously experience was using a 3.5 4 stroke and this gave approximately 3Kn cruising speed on the 2.3m flat floor dinghy with 2 adults. Never measured the range on a tank, the longest we did was 4 miles sight seeing flat calm no tide. The electric outboard at the same speed provides, using the built in GPS range data, of 5-6 miles. However, reducing speed to 2.5kn this went up to 12 miles.
Power, loads of comments that the 1KW rating of the Torqeedo is a lot lower than the, claimed, 3Hp equivalent. This is, subjectively, a non issue. With the dinghy we are never going to plane and the drag is far more a problem than engine HP in this comparison. Both the electric and petrol refuse to push the boat past a certain point so I can say, in my set up, there is nothing to choose between the two. At one point we did rescue a dinghy with 2 adults and 2 dogs and towed them home at above cruising speed (just showing off!) with no problem. Indeed it had plenty in reserve as it was running at 550w out of the 1Kw available on the meter. The range reduced considerably but was not a problem. I should say that the prop speed is a lot lower as the torque at low RPM is comparatively high so for a slow moving dinghy it seems less frantic.
Weight, a small 2 stroke is about the same as the electric. However, the Torqeedo breaks down into two main pieces making it a lot simpler to move around. Compared to the 4 stroke it seems a massive difference but in total is only a few Kg's but that makes all the difference. It is waterproof. With a lanyard on the bits it doesn't really matter if we drop it in the water.
Charging, On all all the trips we did, mainly 2 miles per trip, the battery capacity never dropped below 75%. There is a mains fast charger, 7 hours from flat, but we used a 12v charging lead and this easily charged the battery up in a few hours. Just need to keep an eye on the house battery if you do this. (just over 2.5A draw I think but we did not measure consistently) If you are on mains then this is irrelevant. At no point did we have any concerns on range. The built in GPS is excellent.
Ease of use. Cant fault it. Forward and reverse with neutral and a soft start is, literally, child's play. The GPS that is built in is superb. Allows the unit to display speed, range at current power, and power currently used. No starting issues and the plug and play is reasonably fool proof. everything simply slots together. Storage was the main factor for me. being able to break down the unit to separate parts makes it easy to store. Its quiet but not silent. There is a whine from the motor but its quite low level. Good at not disturbing the wild life.
Build quality. Mostly excellent. One area of concern is the main power connector. We did manage to cross thread the plastic screw down collar. It survived but I am not convinced on the longevity. Will make enquiries on a replacement. Previous design weaknesses seem to have been addressed.
Cost. Eye wateringly expensive! At nearly twice the price of a new 4 stroke.
To sum up.
Pros:
No fuel storage/age/contamination issues.
No mess (2 stroke oil, fuel).
Can be stored easily.
Very simple to use.
Quiet(ish)
Good range, for an electric outboard.
Claims of equivalency to a 3.5Hp motor possible but difficult to confirm.
Cons:
Price
Cant refuel 'on the go' limits the range.
You have to stop and chat to loads of people about the the outboard as its still a novelty
Now that I have one, would I recommend it. A qualified yes. The price is the defining factor for most. Unless you are motoring against wind and tide for hours to reach a mooring its range is more than adequate. I suspect that for most, and many that I have talked to so far seem to qualify, the vast majority of use is pottering around a mooring/anchorage and fits the electric concept. Before I am shot down in flames, I do appreciate that there is a wide variety of requirements of an outboard so this is just one users experience and is intended to help others in the decision making process.
Mike
My 3.5 Mercury 4T will make my Excel 290 Volante inflatable just plane up to 14mph with one aboard.
Therefore the Torqeedo can't knock out any more than 2hp IMHO. Excellent as it is (And ought to be for that price tag!!)
It's a no brainer :-p
Thanks for the review, good to read. Been looking at these for a while but haven't taken the plunge yet, despite being a two-electric-car family on land. Price notwithstanding, I hate carrying petrol on the boat and eliminating that hazard is the biggest appeal of the Torqueedo. 'Range anxiety' could be lessened by carrying a spare battery, in much the same way you might carry a spare can of fuel. If money where no object of course... ;)
I bought a 1003 earlier this summer and use it both on a 2.7m inflatable and on my Achilles 24. In flat water it will push the Achilles at 4.8 knots flat out. Whereas the 4hp petrol outboard gives 5.2. It seems to work well in both and, at half the weight of my 4 stroke, is so much easier to handle!
My main concern to date is that if I leave it in the outboard well when sailing then above 3 knots the prop spins and you get the whine from the gears. So if anyone has a cunning idea to lock the prop I'd love to hear it.
What would be great for a future model is to be able to recharge the battery from the prop rotating when sailing... I guess that needs more electronics and so would cost even more.
This is verboten !
From the Torqeedo Manual......
Do not leave the motor in the water when the boat is moved by other drives (e.g. while sailing, towing the boat) to prevent damage to the electronics.
Great report and well written...certainly food for thought even at that price.....the storage consideration of the unit(s) is very interesting
Thanks also and it reflects our experience over the last 3 years of use. We mostly anchor at night and use it to push a 3m rib which it does at the maximum speed I'd want to do through an anchorage.
It's super clean so storage down below not an issue if we wanted to and we just charge off the house batteries when needed - usually once every 5 or 6 return trips of 1/4 to 1/2 mile. No doubts about starting for any crew member meaning I don't have to leave the boat to go shopping just in case the engine won't start with a pull.
I wouldn't have it if frequently doing 1 mile plus journeys or against significant tides but otherwise it's all positive once we'd swallowed the initial cost. The next hurdle I guess will be in 3, 4, 10?? years time when we need to replace the battery.
+1 I have a 1003 and agree with all the comments - great piece of kit.
Just to add: you can now buy a new large capacity 915 thingy battery which seems to last forever. I let the kids muck about with that and use the small one for back and forth to the shore to escape...
I charge the batteries using the 12v cigarette lighter lead which does seem slightly faster than the mains charger, but might be my imagination. One thing I came across is that if you plug into a socket that is switched off by the main battery switch (ie when you leave the boat) and leave the battery plugged in, it back feeds at 5V and gently powers up all anything switched on... No diode fitted in the charging socket. I actually side stepped this by connecting the 12v charging lead via a separate fuse, direct to the battery and solar panels so that it charges the battery whilst the boat is on the mooring. Seems to work fine as the panels are brand new and work a treat.
The best bit: not listening to my kids mucking about in the dinghy with that hateful piece of arm breaking junk called a Honda 2.3hp whilst trying to enjoy a cold glass of wine at breakfast....ohhh....errrr...
Puggy
Agree with most off what's been said. I have just Brought a new 1003 torqeedo after conceding defeat trying to find a replacement battery for the old type 801 torqeedo. The one disappointment with the new 1003 is no memory on the new battery. On the old 801 you could tell the condition and/ state of charge, the battery would charge 100% but only retain 20%.
In other words Battery nearly dead. Can not do this on my new one. Build quality much better on my new 1003 though.
It not as convenient but the tiller can be connected and this shows the %charge and 'charging' if on charge.
