Tool to remove deck drain?
rosssavage
24 Nov 2006
Windsor, UK
Hi all,
Have to remove my cockpit deck drain to fit new fake teak deck.
Held on by 100mm approx nut (flat to flat) - what's the best option?
Stilsons seem the obvious choice, but the threads are a little manky and I want to avoid knackering the nut. An open end spanner would be too long due to access, and I'm not sure of the actual nut size. Getting to it to check is, of course, a complete bxxxh (obviously, it's on a boat!!)
What do you use?
Many thanks :)
rosssavage
24 Nov 2006
Windsor, UK
Destroying it is a plan b option Vyv - I have two to remove/replace, and the new fake teak deck is costing me enough without replacing the fittings too!!
Already got plus gas on them ready for next week, it's just getting the best tool considering I don't know the actual diameter of the nuts, and have limited access to them.
prv
29 Nov 2009
Southampton
Old blunt chisel at an angle onto one of the flats? Not to cut it (though obviously it will leave a dent) but rather to knock it round until loosened.
NormanS
10 Nov 2008
Correct size box spanner? trouble is it will probably be just as cheap to get new drains.
Yes, but he'll still need something to tighten the nuts on the new drains. Beg, borrow, or steel a box spanner. (Or make one) It doesn't have to be bonny.
rosssavage
24 Nov 2006
Windsor, UK
Done a bit of digging - can get new fittings for about £20 ea, so for ease and speed butchery may be a good option. Could then make / borrow / the right size box spanner to refit... At least i can check it will be the right size for the new one with it preinstall!!
rosssavage
24 Nov 2006
Windsor, UK
Now of course I can't find a box spanner big enough!!
Actually quite like Vyv's idea - I do have a swan neck style oil filter remover that might fit. Plus gas and a bit of heat (careful with the deck GRP!) might work.
Iliade
27 Apr 2005
Shoreham - up the river without a paddle.
www.airworks.co.uk
PetiteFleur
29 Feb 2008
Suffolk
Or, how about a box spanner for undoing immersion heaters? Not got one and don't know the a/f dimension, other the filter removal tool with a chain and 1/2" socket as suggested earlier - I have the webbing & ruber strap version and they work well.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
Or the correct a/f sized "Crow Foot" .
Does these actually work? I don't see how they can be very efficient.
rosssavage
24 Nov 2006
Windsor, UK
Yes, they do. Used to use them regularly fixing planes in a previous life. If you imagine the ratchet drive is locked, it's just a spanner. Adding an extension allows difficult access.
rosssavage
24 Nov 2006
Windsor, UK
Having attacked the plus gas soaked nuts for an hour or so yesterday using two different oil filter remover and the swan neck approach I got nowhere. Cliff's box spanner at £48 is the cheapest proper tool (open ended spanners, adjustable wrenches etc were all north of £100) but I can get new brass deck drains for £16ea from ASAP, destruction is now the preferred (cheapest!) option.
Going to use a Dremel with a cutting disk through the top to mid way through deck level and grind them off.
Thanks for your ideas!! :)
cliff
15 Apr 2004
various
I am sure if you know the AF size there will be a local HGV repair shop that would lend you a box spanner - they use them fro adjusting wheel bearings etc. No need to fork out 50 beer tokens for a one off job
