Tranona
it is a high thrust long shaft 9.8hp optimised for displacement boats
it will deliver 9.8 hp at the prop
the Centaur was designed for a new 10 hp diesel measured at the engine
as I understand it I will delivering slightly more thrust than LG designed the boat for
D
You are tying yourself up in knots about what makes an effective auxilliary. Get it straight - it is the propeller that moves the boat not the engine. The concept you have constructed quoting HP at the prop as being better than HP at the engine is just nonsense. Propellers do not produce HP, but thrust determined by their size, pitch and speed. So that is what you start with and then work back to get the HP you need to turn it at sufficient speed to move the boat.
The boat was NOT designed for a 10hp engine. The original was 13hp, and even in those days when speed expectations were lower than today it was underpowered (that is there was not enough power to turn the ideal prop) and would barely reach hull speed in flat water - but that was all that was available at the time. The 23hp engine was fitted to later models because that was the next size up. If you look at most of the re-engine jobs you will find the 18-20hp range is the most commonly fitted because that is the appropriate size.
So, you are deluding yourself thinking that the outboard will be a satisfactory auxiliary for when you get to the more demanding part of your journey.
Equally your long diatribe about the inadequacy of small diesels is so far from reality that it is almost impossible to believe you are serious. I know your view is based on your experience with your ancient Volvo, but that is a bit like saying I won't have a Fiesta because I once had a Popular (which I did and remember the wipers that did not work, the need for a decoke every 10000 miles etc.). Modern diesels are as far removed from your old nail as a Fiesta is from a Popular.
You want a reliable boat and engine for your journey. Why are you thinking about a knackered boat and an inadequate engine when you can buy a complete boat for similar money which will do everything you want - and then sell it afterwards, probably for more money as the "been there done it" ex KTL star.
