Toast
Wansey….is there electricity available on the quay ?….an extension cord and electric toaster is all you need
I had a toaster similar to this but better made, it worked perfectly with a gas stove and with an Origo stove.
To make a marmalade sandwich, for example, you put the marmalade between two slices of bread, butter the outside of the bread to prevent it sticking to the toaster, clamp the two iron shells together and cook it for a few minutes over the flame.
You can get similar things with rectangular shells.
Cruise to Taiwan. No Killer whales here AFAIK. They would probably eat them.
Here, "toast" in Tchinglish, just means white sliced bread, as bad, or perhaps slightly worse, than white sliced bread is in Blighty, or more specifically Scotland, but more expensive, and without the carbonisation.
I have tried to convince them otherwise, but I'm told I just dont understand Taiwan culture.
Daiso (Japanese "pound shop" analoge) do a cheap camping "waffle iron" thing which might work, and which I might try. There are quite a lot of such outfits doing camping stuff in Japan, but I dunno if any of them have a presence in Europe.
Does it seal the slices with a tempting pointy corner which you bite off and get a shaped-charge stylee jet of superheated steam and marmalade down your throat, like a real toasted sandwich maker?
Cést magnifique, mais ce nest pas le pain grillé Cést plus comme la guerre.
Even looks like a landmine.
Six in the morning,just had a brilliant idea……all the rage in posh restaurant kitchens is the gas gun used to brown suffles or for paint stripping.You could lay the bread of choice on say a slate tile(another fashion item) and waft the camping gaz thingy over it and brown to choice then arrange cheese on to and repeat and or just butter and you have the added bonus that you have a useful tool for boat maintenance…..🤷‍♂️
A chef’s blowtorch. Super useful for sealing rope ends too.
Just got a new boat and already thinking of ways to burn it to the waterline
If your single burner is one of those camping ones with the cylinder next to the burner, take care. Or you could end up making more toast than you can eat. Keep a fire extinguisher to hand nearby.
I had a boat with a single burner camping stove for years and managed toast, three pan meals etc with no problems (except for one small fire...).
I used to have a proper pyramid toaster many many years ago but don't know what happened to it. It worked very well. I lost it some time ago. I tried to buy another, but all I can find are those flat ones with fold up wire stands for the toast. That is utter rubbish.
So if someone finds a source for the proper pyramid toaster, PLEASE post a link on this thread.
Cast iron skillet ( shallow lipped frying pan) was my Go To for years. Also makes something called an omelette or The Full English.
But most cheap ones have far too short a handle . Which gets hot
I like chef Wanseys blowtorch idea
Hope he doesn’t decide to charge chef prices for a bit of toast and marmalade maritime though 😎
I bought ours from Black & Edgington, now Blacks, but I've had a look on their website and the Pyramid is no longer savailable.
I reckon your best bet is to do a saved search on eBay UK. There's a few on eBay USA but the carriage charges are very high.
The old fashioned ones I think you are referring to seem to be hard to find this side of the pond these days. (Perhaps I could make my first million smuggling them in from the USA?)
In the meantime, perhaps not so elegant but these ones seem to operate on the same principle, and are available from Force 4 (and likely other outlets).
Force 4 Gas Ring Toaster | Force 4 Chandlery
