Butane without a regulator!
craiglockwood
18 May 2013
South Wales
I've recently acquired an old Centaur and have been checking her over. There is a Plastimo Neptune 2000 2 burner and grill in the galley, which ar pretty common. Decided to make a cup of tea so went to locker to turn on the gas to discover the previous owner has been using it without a regulator! Surely, that's not right?
Obviously I will be fitting a regulator immediately, but just wandering if anybody else has come across a boat using butane without a regulator?
The label on the stove should say which gas ( butane or propane) it is designed for and at what pressure.
I have had two camping stoves ( I still have one of them ) which operated at high pressure ie without a regulator, not even a built in one. I would not want to have used them on a boat though.
I recommend that you read the section of the Boat Safety Scheme relating to LPG installations to get an idea of what is acceptable (mandatory for inland waterways craft)
https://www.marinesurveys.net/BoatSafety/Guideline-chap7LPG.pdf
