Tips/tricks to ease removal of rubber hose from sea water pump
ralph s3
10 May 2021
Hi All,
I need to remove the inlet hose from the sea water pump on my KAD32 diesels so that I can connect another hose to draw anti-freeze into the raw water cooling system for winterisation. However, I know from last years battle that getting these pipes off is a nightmare as they are rock hard and I have hardly any space to work in. So I'm wondering does anyone have some tricks to ease removal? I thought about using a heat gun to warm the pipe but it's quite near to the belts (although I could remove those). I also wondered if there was some kind of wrench which I could use to grip the hose to move it from side to side while pulling down? I don't want to use hose picks etc as I don't want to damage the hose for obvious reasons. I'm even wondering whether I can rig up a circuit using a spare bilge pump to force the anti-freeze into the top of the outlet pipe within the filter basket but I would have to do that without the engine running and I'm unsure if that risks water finding it's way back up the exhaust into the engine.
Any suggestion gratefully received.
Ralph
jon and michie
28 Dec 2014
When you're ready to put the pipe back on put some vaseline on the inner part of the pipe which catches the brass fitting - Next time will be easier to remove with just a wiggle
Clash
1 Dec 2024
You could also use this tool. Depending on access of course, but seems to work in almost any situation. About 1:30 into the video.
ralph s3
10 May 2021
Thanks all, I'm going on Saturday armed with a small oil wrench with a rubber strap, a hose pick as per the above video, hot water, a hair dryer and a heat gun. If none of that works I will give it a stiff talking to. I will report back as to what is most effective
Clash
1 Dec 2024
Best of luck. It will probably be a combination of heat and the pick.
Neil1300r
19 Mar 2024
Every days a schoolday. Got to winteris my new to me S34. Been reading up what to do and was concerned the pipe may not come off easily. I was then going to ask what the tool in the video is called, but just googled it. I won't be doing mine untill the end of the month when the boat gets lifted out of the water. Where there is no shore power so the foredeck crew's hairdryers won't work
