Times, they are a changin' (or are they?)
qsiv
30 Sep 2002
Channel Islands
Sybarite
7 Dec 2002
France
Re: Times, they are a changin\' (or are they?)
I inherited a deviation card that showed a max of 3°. Nobody on the boat can steer constantly to that precision.
When I head on a long crossing I check ( for the course I am taking) the fixed compasses with the bearing compass - not affected, at least, not to the same extent, by deviation - and double check it with the GPS. (Remember to take metal frame glasses off when using the bearing compass).
You then know for that heading (or those headings if you have to beat to windward) what your realistic deviation is.
All the recent checks indicate that the original deviation card is still valid. In calculating my courses I usually ignore it as the other influences - tides, leeway compass variation are collectively normally much more important.
This has worked for me including several DR crossings in the Med and from Britanny to Scilly in pre GPS days.
John
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
PS on compass swinging
Missed Alderney once, in pre-GPS days when I was ferrying a cruiser racer down to St Malo for the owner to take off on the family cruise. My nav is not normally that bad, and the other lads on the boat were all capable of steering a good course. Much fiddling with the DF established sort of where we were, and we steered the rest of the way using the h/b compass. We knew the boat and we knew the compass was reliable. When we got to St Malo we tried to check the compass on various transits but could find nothing amiss. Told the owner who was good at those sort of things. He immediatley started looking for what was different from normal. Answer, an outboard clamped to the stern rail, about 3 feet away from the compass. But, when the boat was flat it had minimal affect. He wondered if the problem was to do with the vertical position of the o/b when the boat was heeled (it had been a one-sided beat across). So we lifted the outboard a couple of feet in the air and a little closer to the compass, which promptly swung by about 25 degrees.
<hr width=100% size=1><A target="_blank" HREF=http://www.writeforweb.com/twister1>Let's Twist Again</A>
peterb
Radlett, Herts
Specs
Careful. It may not be the spectacle frames that are the problem. I had one pair on which I finally traced the problem to the little screws that clamped the frames round the lenses. Some opticians use magnetic screwdrivers to hold them while they are tightened.
