BruceK
I've been relegated to a Dingy
However should my fortunes change and I get a "big" boat I shall heed the advice
I think you're right that the locking turn may have saved the boat, but that\'s a poor excuse for not using the cleat properly in the first place.
I think you're missing the point.
If the locking turn has pulled so tight that it needs cutting off, then that may well be a result of 'not using the cleat properly' (and I wouldn't argue with that) but it's very clearly the case that the locking turn has saved the boat if it's undergone that much pressure - without it the warp would have just eventually pulled free.
However, if the cleat is 'used properly', ie the locking turn hasn't been subject to any pressure, then it's never (ever!) going to be a problem to undo.
So a locking turn is clearly 'best practice' because it's a win/win. In a worst case scenario (poorly secured warp) it's possible it would save the boat, and in a best case (that it's unnecessary because it undergoes no strain) then it's never going to be a problem.
In over thirty years of using locking turns I've never ever had the slightest issue undoing them, and it neatly and effectively secures the tail of the warp.
It's an obvious and eminently sensible way to finish.
Exactly the same argument could be used by those who put a turn around the cleat to finish it off.
I’ve never had one come undone or fail. As I’ve said before, you can choose, but I note that many experienced seamen join me in choosing not to use locking turns.
Precisely. That is a perfect analysis. If the lock goes turn jams then you really needed it and praise the lord that it jammed and you had to cut it.How was the line otherwise secured other than the locking turn? If the boat jiggles against the warp and the locking turn gets tighter it seems that there must be undue force reaching that turn that you'd otherwise expect to have been taken by the other turns (OXX or OOXX etc), as it must still be slipping. If the line was otherwise secured well it may be the case that the locking turn saved the boat
Again, that is a perfect analysis. Clearly correct. A locking turn is best practice. Those who understand things from first principles can see that; those that just say something is right because another guy told them it was right without being able to offer a first principles reason might suggest otherwise.. In this thread no one has stated a cogent reason for not using a locking turn.I think you're missing the point.
+1 :encouragement:Nobody has said your way was wrong, or that it is even easier. What I find so delightful is none can give a credible explanation as to why it's the only way and that all else is "devils work". To be a little bit contentious the two in juxtaposition just smacks of ignorance by means of learning by wrote and delivered with all the piety and self confidence such ignorance brings. Nothing personal here, it's just something that seems more prevalent in the boating world than the norm.
I definitely read it properly. I spotted that you hadn't actually failed anyone. That's why I said "theoretically". You introduced the concept of this being relevant to pass/fail and I commented on that. But "theoretically".I don't think you read my post properly?
John as I see it you are not grasping the logic here. See posts above by Ari, Sorabain et al. If the locking turn jams you needed it. If it doesnt jam then the one single downside you cite (being jamming) doesn't occur. Ergo locking turn is better than not. The logic, and the flaw in your argument, is crystal clear imho.Before you lot get too smug and start making (false) claims about best practice I’ll offer you this.
You tie up and use 088 and make off. The weather is foul and like a good seaman you periodically check your lines. You find that the 088 hasn’t been enough to prevent slippage; you need to add a couple of more 8’s to the cleat and start to double up. How you made off now becomes important. An 0880 can ALWAYS be undone but occasionally a locking turn can’t.
99 times or more out of 100 you’ll get away with a locking turn. It seems so easy and obvious. However a turn around the bottom of the clear is just as secure and can always be undone (the turn sometimes jambs hard underneath but you’ve got a whole tail of line to pull on to extract it) so it’s never a problem. If you don’t think a turn round the bottom of the cleat is secure, then try it sometime.
As I’ve said before, I might have over egged my argument when I said locking turns are the work of the devil, but please don’t pretend they’re the end of the discussion and ‘best practice.’ After all if the locking turn is saving you, you’re using the wrong sort of mooring lines or you’re not using the cleat properly.
Fine, fair enough.![]()
So, remind me again why it's in any way an issue?
