BruceK
:encouragement: but I've got to ask, for what are you planing on getting a quick getaway from?
With 15 boats rafted up, there are several potential situations when a rapid release might be needed.:encouragement: but I've got to ask, for what are you planing on getting a quick getaway from?
If you want to be ready for a quick getaway, use separate lines from each boat cleat and thread them through the pontoon cleats and secure them back to the boat cleats.
I'm struggling to get head around this but if I did encounter such booby trap cleats I'd chuck them out. That very nice/knowledgeable/ experienced guy saying oxxo in the video, Jon Mendez- his boat is a storebro like the one in your avatar, isn't it?...you have obviously not encountered the very shiny and elegant looking cleats that Storebro fitted in the late 70s. Almost any type of fastening will slip on these under load especially if it is variable.
With modern rope materials I always use locking turns. It has nothing to with securing the boat at that moment, for which Oxxo is fine. It is to stop the thing being interfered with. There might be people cleaning the boat all week or whatever, and the locked hitch tends to make them not touch the thing whereas the last O in oxxo, which will always be very loose, might get moved by a cleaner or child who thinks the rope is just wound around ( which it is)'and would look tidier put away, etc. So I'm oxx-lock, generally. I totally don't buy the quick getaway angle.
BYW, I wouldn't accept being failed by an RYA yacht master examiner on this point if, theoretically, that were to happen. Examiners are not gods and do not have that level of discretion. Entirely theoretical point I think.
I still think that locking turns on big boats are the work of the devil...
Do you know why you think this?
By the way, the proper way to moor up is to return the lines to the boat. This is the prevent the (very real) possibility that a crew person slips while trying to reboard after releasing the lines.
Yes it wasOr was 'The proper way' intended as ironically pompous?
To be honest I do OOXXlock. The extra zero is to prevent slipping.
Because they can lock up when a large boat jiggles against the mooring warp. I've ended up having to cut a mooring line off a cleat. You only do it once...
How was the line otherwise secured other than the locking turn? If the boat jiggles against the warp and the locking turn gets tighter it seems that there must be undue force reaching that turn that you'd otherwise expect to have been taken by the other turns (OXX or OOXX etc), as it must still be slipping. If the line was otherwise secured well it may be the case that the locking turn saved the boat
