Temporary fixing of plastic pipe
dgadee
13 Oct 2010
I want to use a plastic 40mm waste pipe to run wiring along in the cockpit locker. I want it up under the deck. How do I get the pipe to stay in place so that I can put some fibreglass fastenings in place? I just tried CT1 but the grab is no good, or I am not using it properly.
Tried tape. The problem with fast grab is that it's not fast grab enough - or perhaps I wasn't holding it in place for long enough. Never really had much luck with that stuff.
I might have to wedge it in with battens.
CT1 is more flowing than Power Grab 'n' bond and so, as you say, there can be time for the pipe to fall. Put all my ceiling battens on with PGB as well as electrical conduit where the self-adhesive backing wasn't enough (following the curve of the hull side). Doesn't need holding for long.
I think there will be about 6 cables going along this - 240v arctic cable, 2 x solar 6mm, 2 x power/network to autohelms, rear nav light.
P-clips are available in sizes to suit holding a 40mm pipe in place. If your cables fit in that pipe, then they'll certainly do the job of holding that pipe where you want it.
Might work. Can't remember if there is just a single fibreglass layer there. Might be in which case screws would come through. Will take a look. But will get Power Grab 'n' bond first. Pity Screwfix (a few minutes away) doesn't do it.
If your boat is new enough the fibreglass is very consistent in thickness and you can use very short screws. If it's old enough to be from the "made by a man with a bucket of resin" era it may not be. And that's how I ended up with a row of evenly spaced tiny point repairs that don't quite blend in, on only one side of my coachroof gelcoat. oops.
ps really hope the pgb works for you and is not too much trouble to get.
It's a Fulmar. Old technology.
