Telltales on Gennys
[194224]
11 Oct 2022
The leech of a foresail can get quite a lot of harsh treatment during even the smoothest of tacks. There can be quite a bit of flogging and as it passes the mast one way then the other the telltales can get a bit of treatment.
TLouth7
24 Sep 2016
Edinburgh
Leach telltales do a different job. They’re telling you if the flow is still attached as it reaches the back of the sail.
A genuine question - is it even possible for the leach to be separated without a separation bubble at the luff?
You need leach telltales on a mainsail because the luff is so affected by the genoa/slot that luff telltales would tell you nothing useful.
Spirit (of Glenans)
28 Mar 2017
Me; Nth County Dublin, Boat;Malahide
Some also have them across the sail.
Not sure I would want them as I don't need something visual to show me how bad I'm sailing !
The ones across the sail come into use when you have reefed/ partly furled the genoa.
It's quite easy, after a bit of practice, to trim the sails with the help of the telltales.
The trick is, you then, observing the telltales, either steer to the wind shifts, or continually trim to maintain a steady course.
Minerva
16 Oct 2019
Surely leach tell-tails on a Genoa wouldn't last particularly well - even when the sail is furled away, the tell tails would still be blowing in the wind and eroding away...
flaming
24 Mar 2004
Oh very much so. If, for example, you are too car forwards then the top leach telltale will not be flying as the flow might enter the sail ok but will be asked to do too much by the sail and stall, resulting in turbulent flow and drag. In upwind the leach telltales are for the trimmer to gauge the twist and the slot (in conjunction with the main trimmer) the luff telltales are for the driver to point the boat properly.
flaming
24 Mar 2004
I had much more difficulty with getting leech telltales on the main all streaming in tune but did the best I could, top one was a the usual bugger.
That's actually what you want. A good main trimmer, in upwind mode, wants that top telltale streaming only part of the time. The ratio of streaming to not depending on if you are in height mode or power mode. A good rule of thumb for best VMG is that you want it flying 80% of the time.
If you're going for max height for tactical reasons, giving up a bit of speed and VMG, then squeeze the sheet until you get to maybe 50% of the time streaming.
Once you're not trying to point, i.e you're close reaching, then look for almost always flying. In any sort of chop you'll be unlikely to get always flying as the motion of the boat is amplified at the top of the rig and can whip the top of the sail forwards and backwards, but if it's mostly flying then you're good.
If you're struggling to get the top telltale to fly once you are reaching, then try easing the kicker. Also pay attention to which way it is going when stalling. Lying on the windward side of the sail means you are under trimmed, Lying on the leeward side of the sail means you are over trimmed.
johnalison
14 Feb 2007
Essex
This is all very good stuff but although I pay attention to the leach telltales I can't usually be bothered with the jib ones. I can't see them from the helm unless I sit downwind and peer up at the sail, which is not the most comfortable position to be in with a tiller. My boat, an HR 34, is not as sensitive to jib adjustment as its 340 successor, and I have learn how to set it in most winds well enough that I can judge the sheeting from the helm with only the occasional visit down to look at it.
goeasy123
10 Nov 2018
OP here. I just ask as I'm watching yachts with bejezus big genoas sailing across the Ionian with a ton of drag slowing them down.
blush2
26 Dec 2008
My thought exactly. Tell tails on the main have a limited life.
BobnLesley
1 Dec 2005
Aground in Yorkshire awaiting a very high tide
Exactly! When our mainsail ones faded/eroded I cut away the remnants with the intention of replacing them, then didn't bother; it removed an awful lot of the frustration and aggravation from sailing.
Daydream believer
6 Oct 2012
Southminster, essex
You mean that you cannot be bothered to set the sail properly. That is a bit of a poor admission to make, on a sailing forum. But to each his own I suppose :rolleyes:
