Taylor’s cooker
Geoff A
15 Jan 2023
Replacement safety on-off fuel control valve for a Taylor’s cooker are over £100. My new to me boat has one with two burners with an oven.It needs a new valve as the existing one when under pressure leaks from the spindle that is part of the control knob. There is no way that I can see where it is possible to take it apart so that new internal parts can be fitted. I think I have found an alternative company where I can get a new valve. Can any one tell me what the operating pressure in the main tank should be, please. From what I can find out about them people either love or hate them. If I was to strip it out what would a fully working cooker
be worth? As I have not tried lighting it at the moment I do not know if I want to keep it or sell it.
I cannot give you any technical advice.
I am looking for a regulator/valve (that is the knob that makes the flame bigger or smaller), for the oven of my old Taylor gas stove.
Maybe just tell us the alternative company, if I may ask.
Or the source for original spares.
Thanks, G.
Every part of a Taylors cooker can be dismantled, which is why they last for years. See the handbook here: https://www.sparesmarine.co.uk/_webedit/uploaded-files/All Files/Taylors Paraffin Cookers.pdf
There should be a sealing graphite bush on the valve spindle that you can tighten down on with the nut or replace if it is worn out. The 4 legged Hanse burners are excellent if excrutiatingly expensive and are a great improvement on the terrible 2 leg burners fitted in the past when the originals became unavailable., As Napoleon, the pig, said in Animal Farm, four legs good two legs bad.
Thanks, G.
If you google Taylors cooker their web site will come up it has a full spares list with prices. The reason I have asked for the operating pressure is the alternative company's control valve may or may not be any good.
I operate mine at 15 psi but that is with Hanse burners. There is more about the stove here: The Taylors Paraffin Cooker! – Sumara of Weymouth
Do you mean the stopcock/valve between the tank and the cooker? Or the needle valve that is part of each of the cooker’s burners?
The former should be more like £20 (I’ve bought one in the last year or so, will look up details tomorrow), the latter is an easy rebuild with spares readily available.
Blake/Taylors manufactured a small proportion of the parts of the cookers (the bodies, cast iron parts, gimbals); the rest were made by third parties, specifically all the fuel-line and plumbing parts and burners - and if you go direct to source the parts are dramatically cheaper. Unfortunately the company that made all the pipe compression joints ceased production in the last couple of years - but those are the parts that are least prone to failure.
It is the valve between the tank and cooker. Looking at the Taylors price list they are about £120.00. see photo. To any one else reading this thread I have not decided to sell or keep the cooker. I would like to know a reasonable asking price if I decided to sell it.
I fitted one in the 80's to a boat that would be cruising for up to 6 months each summer as far easier and lighter to carry paraffin for the cruise rather than Calor gas cylinders. I don't remember a pressure gauge on the tank, just pumped it up till pumping became hard and pumped a bit more if the burners started to go lower. However, some people did not like the smell. Years later, having changed boats, I was visiting on another boat with one and decided that I would not want to go back to it for that reason.
