Cymraeg
Hi all,
I've got an issue starting one of my engines - when left for a while the port engine takes an age to get going, then 'chugs' for a while before settling down. Subsequent starts are on the button until the next time it's left for a while. I've found that pumping the manual fuel pump primer a few times helps considerably, so I assume it's a fuel pressure problem. Starboard engine starts instantly every time. Could it be something as simple as a failed non-return valve, or do I need to look for something else? Probably on the boat at the weekend so can perform any checks anyone suggests.
Thanks.
Thanks.
