bowler
Hi all,
My port engine is showing signs of diesel in the oil. Both engines had an oil change earlier this year and there has been about 12 hours put on the boat since. The SB engine oil is certainly darker while the port engine oil is lighter and has a diesel smell to it. This engine also has a slight rock to it at low rpm. My plan was to pull the injectors and have them tested. Could the injectors be the cause of these symptoms? The oil is still around the max mark on the dipstick so not huge volumes of fuel I assume. I should add that the oil change was done by the previous owner so I am unsure of its condition.
If not the injectors then what else?
The only marine diesel mechanic I know can't get to the boat until late September so I guess future trips are cancelled for the time being.
Many thanks.
Many thanks.
