LadyInBed
Are Sta-Lok and Norseman cones interchangeable?
Probably not! so does anyone know how to identify one from the other?
I would be very sceptical of the wisdom of substituting one for the other.
I don't want to substitute, I just want to get the correct ones.
So Noresman may be shorter with a steeper taper, that's a good start![]()
One of them has a cup shaped thingy as well as a cone. Cant remember which.
I presume the furling gear mentioned earlier was a furlex, and should definitely have a former, if it doesn't fit you have done something wrong (often they get stuck up in bottom end and you don't notice they are there and try to put in a second).
