Yngmar
I thought I had some understanding how these things work, but this outboard puzzles me.
It's a Suzuki 4-stroke 2.5 HP (yes, everything is really tiny) from 2008 that came with the boat and sat on the rail idly for 2-3 years, so of course the petrol had gone off. The ignition also had problems, which are sorted now after replacing the all-in-one ignition module. Spark plug is also new. So now it starts, but only runs for a couple seconds at most, often just a few turns.
So far I've rebuilt the carburetor entirely (see photo), getting all the tiny jets and nozzles out, and even taking the float and needle valve apart, soaking everything in carb cleaner. There was some gunk on the main jet and on the one with the smallest nozzle, which I think is the pilot jet, but they all cleaned up nicely and I can look through them when I hold them into this nice sunshine we've got.
I've also refreshed the petrol twice, cleaning the tank and small fuel filter inside the tank (took me a while to notice there was one). Fuel hose is good and when opening the fuel valve, plenty fuel comes out. I've put in fresh fuel and tried with both a low and a very full tank, made no difference.
The spark plug was carbing up during my many start attempts, from which I conclude there's plenty of fuel coming through? The air intake is a very simple plastic thing on the side of the carburettor with a large mesh and definitely clear.
It has a manual choke, which needs to be pulled out to start. Shoving the choke in after starting makes it die off quicker. The throttle setting during starting has the expected effect - it revs up accordingly. However, it doesn't seem to throttle up after starting. If I spray some starter spray in, it runs maybe a few seconds longer.
The fuel drain screw at the bottom of the carburetor is unfortunately seized, making it difficult to check the function of the float and needle valve, but there was plenty of fuel in the carb sump each time I took it apart after it died on me. Had it off about 4 times now and am a bit lost.
What do I check now? :dejection:
Parts diagrams are here: http://www.suzuki.com.mx/marinos/img/Catalogos/DF2.5_9900B-45245.pdf
Unfortunately a workshop manual for the 2008 model doesn't seem to be available online.
