Supplier of oversized/large plastic washers/shims?
fredrussell
24 Mar 2015
I need a few large plastic washers for a project. 70mm OD, 39mm ID, by 2mm thick.
Does anyone know where such things might be found?
2mm thick, buy plastic on ebay, cut with fly cutter or even scalpel. If you have the right size hole saws that's maybe better still.
I've just cut some for dinghy trolley wheels. Cut one set from an old oil can, about 1.6mm thick, another from an old drill case about 2.5mm.
Not precision engineering, depends how accurate you need.
If you go this route, cut the larger diameter first or you lose the centre.
Starrett used to make a hole saw holder that took two hole saws for when you drill the wrong one first or need to enlarge an existing hole - quick google and they still do Starrett A19 OOPS Arbor for Hole Enlargements: Amazon.co.uk: Business, Industry & Science and appropriately named
