webcraft
Our stormboards are made and now we have to work out how to attach them to the boat.
Simplest is obviously just bolt straight through the cabin topsides with 6mm bolts and penny washers but . . . we do not want to have them in place all the time, so how to seal the holes when they are not there?
The easiest solution would seem to be to put short dome-headed bolts through sealed with a rubber washer of some sort on the outside. The question is - what sort of rubber would provide the right amount of compressibility to make this waterproof? I have some nitrile left over from sealing the fuel tank, but something a bit softer might be better.
Second question . . . I have a piece of 6mm lexan and would like to make a couple of small ports in each of the boards so it is not pitch dark when they are in place. I would like to cut 4" or 5" lexan circles, mitre the edges then glue them over 2.5" or 3" holes cut in the plywood, but have the following questions:
~ How do I cut/machine the lexan?
~ Is glue the best way to fix it over the openings? If not, what?
All suggestions / comments / derision welcome as usual.
- Nick
- Nick
