Squeaky
Good afternoon:
I have a stern tube which ends a few inches inside the hull behind the aft bulkhead of the engine compartment which means that any messing around with the stern tube greaser/fitting has to be done behind the bulkhead which is only accessable through a cockpit locker (after removing the locker divider and everything stowed in the locker).
I increased the length of the stern tube by adding an extension pipe of the correct diameter so that I can work on the greaser from the engine compartment access through the port locker without removing the divider and stuff in the aft section. This is much easier.
Has anyone any experience of replacing the entire stern tube with a longer length of material?
If so, what material was used and where can it be obtained?
What is involved in getting the old stern tube out - how is it removed?
You might ask what is wrong with the present setup - I don't like nor trust it and would feel safer and better it was done correctly with one complete length of material.
Thanks in advance
Squeaky
Thanks in advance
Squeaky
