Spyro
Anyone got any advice on replacing stern tube gaiter I was wondering if it can be done without removing the shaft completely I hope to be able to seperate the shaft from the gearbox coupling and pull backwards. I have about 12 inches between prop and rudder to be able to do this. Main concern is if I will be able to slide the gaiter over the gland. I don't want to dismantle the gland as it is working fine with no leaks.
Yes the boat will be out of the water.
Thanks Ian
Thanks Ian
