A
Alcyone
Guest
We're in the process of fitting a new Beta engine to our Cobra 850. Old engine is out and sold, boat is on it's cradle out of the water. When I asked here about doing this, a few people suggested we look at changing our Stern gear whilst we are at it.
Our stern gland leaks, amaybe around 1/2 a bucket a week, and I found a fair bit of play in the prop shaft this afternoon. I'm new to all this, so some advice/exlplanation would be appreciated.
First the Stern gland.
This is it. When I removed the prop shaft, I found that there was nothing in the rubber tube, apart from grease applied via the white tube and remote greaser. I'd expected some kind of packing?
When I removed this, I found the stern tube:
If I buy a new stern gland, does it just fit onto thie end of this, held with jubilee clips? Also, what kinds of stern gland could I/Should I look at?
The bearing concerns me more:
When I've seen pictures, there usually seems to be raised and recessed areas on the inside of the bearing. Has mine completely worn away? Am I even looking at the right thing?
Any help, as usual, much appreciated.
A.
A.
