Mike47
New Member
You are so kind !!! The boat is a cobra 850. The orginal thread was assocaited with a cobra 850. Hence the link. Fhe outside nuts are domed like the inside. The bearing is fine as ive just had a new engine installed and prop shaft etx. The leak of weep is from.the lower bolt. Of fhe tsp.holding fhe housing in place if that make sense. Thanks for your help
