pvb
Their current brochure uses exactly the same description as to how the unit works.....
"We put a "load" on the alternator to pull the alternator voltage down. This fools the alternator into thinking that there is a major drain on the system and as such, the standard regulator works at full current. However, the voltage is pulled down to a totally useless voltage for charging batteries. So the new system takes in this high current, but low voltage, and amplifies the voltage to charge the auxiliary battery bank at a much higher voltage than the base system voltage."
Aditionally it now has a new 'FEATURE":
2) Alternator temperature sensing: This disengages the unit in the event of the alternator temperature getting too high, it then re-engages the unit when the alternator cools down.
So nothing has changed except that it maybe 'turns off' the alternate for much longer to let it cool down for more than 3 minutes. This not only makes the charging much less efficient but also means it will take much longer.
Not a new feature at all. Exactly the same feature was included in the 2007 brochure which you got the graph from in post 14. Here's what the 2007 brochure said...
