Steps at top of mast
KAM
6 Jun 2005
I normally climb the mast using climbing gear but was thinking it might be useful to have a couple of steps at the top for a rest. I bought them a few years ago but not fitted yet. Has anyone else done this. Useful or a waste of time?
footsoldier
4 Aug 2006
UK and France
I have often thought it would be a good idea if you need to be up there for a little while - both to ease the discomfort of a harness/bosun's chair, as you suggest, but also to provide a means of bracing yourself if you need any leverage to undo a fitting.
NormanS
10 Nov 2008
I made fixed steps for my mizzen mast, but used folding steps for the main mast. They are probably slightly better. Even if you're not going to fit steps for climbing, yes definitely fit a pair at an appropriate level for working at the masthead.
veshengro
23 Jan 2023
I fitted four fold down steps on the wooden mast of my Gaff Cutter. They were heavy aluminium mouldings, quite stream lined when folded up and never caused any problems at all. I fixed the top pair at a height which allowed me to be above eye level with the Truck. I don't know how to highlight Photos, but the steps show between the Spreaders and the Mast Band> Standing on the steps with a lashing round my waist I could work with both hands on the light/masthead fittings.
Sea Change
13 Feb 2014
I recently spent three hours at the masthead fitting a wind instrument. Steps would have been a huge help!
I couldn't actually reach the masthead using the bosun's chair because the design of mine has the attachment point to the halyards too high. So I had to use a climbing harness instead, which allows an attachment point right down at my waist.
I found that by slackening off the genoa halyard a little, I could get the top furler swivel to slide down a bit, and it was then a good height to use as a perch, allowing me to work relatively comfortably.
PabloPicasso
12 Feb 2010
My bosun's chair has footstrops so I can stand up at the mast head.
It is a self climber type so I can climb and descend without help. I feel a bit like a a caterpillar going up, and it is an effort.
Fr J Hackett
26 Dec 2001
Saou
Absolutely invaluable, place so that your waist when standing is just about or slightly below level with the mast head secure yourself with a short strop around the mast and you can work there comfortably.
dansaskip
12 Nov 2004
Various
seabear.uk
I fitted steps all the way up my mast, so much easier to climb the mast with them but I also use a climbing harness with a with a jammer tied off halyard as safety plus a sling or cows tail to clip on at the top so I can work hands free.
rogerthebodger
3 Nov 2001
I fitted folding mast steps all the way up my mast and at the top.
The error I made was that I have twin back stays starting from the mast head so to need my mast steps at I height so I could straddle the backstays, so my crutch did not run on the backstays,
Only found out after I had fitted the mast steps
Ray Purchase
1 Jul 2024
What ever you do, get a rivet gun that's man enough for the job. I did the whole mast and used a hydraulic one (hired), my hands are intact...just.
geem
27 Apr 2006
Caribbean
My main mast has steps at the top. Really useful but make sure you place them carefully. The previous owner fitted mine but they are in a less than ideal location. Too close to the top. Ideally you want to be able to stand up straight with them and be able to see over the top of the mast to work on the nav lights, etc
