co256
Doubtless Entrenched Brain will be back tonight to haunt you as the ghost of shipwrights past...
A spark flew up his trouser leg
And I wonder if a moderator can think up a suitable next line.![]()
Show me where I've suggested that you immediately abandon your boat and take to the liferaft.
Any seaman worth their salt knows that you step UP into the liferaft as a last resort as the ship/boat sinks underneath you.
Or in the case of a steel boat as it becomes too hot to stand on the steel with the fire roaring away inside. Any decent seaman knows that a properly built boat is well ventilated and although its POSSIBLE to seal much of the ventilation off, its also time consuming and slow. I've got several dorades and water resistant ventilators on my boat and the screw on caps to seal them off are stored below. Bit tricky to seal off the ventilation when you've just been beaten back by the flames, smoke and heat if you can't access below decks and you certainly daren't risk opening a hatch and introducing a large volume of air and inducing a fireball flash back.
Better to have the option of a liferaft as a final resort that listen to extremely dangerous advice from someone who is making it clearer and clearer that he is a liability at sea. I don't mean to be unkind, but some of your suggestions and guidance are risible and dangerous.
Tell us about any firefighting courses you've done....
I also strongly suspect that the yacht that burned out its interior in San Franscico was ashore. Or are you going to claim that every seacock was shut?
Does the forum owner have any responsibility for potentially dangerous advice given about fire fighting by just shutting the door and hoping for the best. I would hate for someone to take Mr Swain's advice and end up on fire in the drink/dead because it did not work.
Ah what you fail to realise is that anybody who puts to sea in a boat not fitted with the Brent Swain Industries patented hermetically sealed companionway hatch system is a raging fool.
While these problems may occur with a small number of boats and Tom is right to warn people looking to buy older well used GRP boats, they are the exception and the vast majority of boats in numbers that outweigh the total number of steel yachts built do not suffer from such problems.
On the other hand the majority of steel boats historically suffer from corrosion, many to the point of ending up worthless.
You can huff and puff all you like but I am afraid the facts are against you.
If only you could open your eyes and your mind to what is really going on. But of course you have a history of not doing that so really a waste of your time and ours.
[/URL]......
Are you in the liferaft selling business ?........
Originally Posted by john_morris_uk![]()
[URL="http://www.ybw.com/forums/showthread.php?p=6288561#post6288561"][/URL]
I think you will find that JM is.
Sort of :encouragement:
How does the fire get roaring hot with no oxygen? My wood stove doesn't even do that.
If that is a possibility, then why didn't my boat do that?
If as you claim, what I did wont work, then why did it?
How do you consider seaworthy, a boat which cant be easily sealed?
I had 2 cowl vents , and two more six inch vents, and the hatch to close, to seal her. Took seconds.
After arriving in the next anchorage, I waited the entire afternoon before opening her up, ready to close her instantly, should there be a problem.There was none.
Keep it simple, for seaworthiness.
99% of steel boat owners I know, consider their steel hulls to be their life raft. Many have huge amounts of ocean cruising experience.
Not the case with non metal boats.
Are you in the liferaft selling business, or just trying to discourage those who cant afford the huge expense of a life raft from considering going cruising?
Just when I thought this thread was fizzling out it's gained a new lease of life.
John - just about every authority I have ever heard venture an opinion since the 79 Fastnet has recommended staying on the boat as being the best course of action.
And another benefit of steel for the cruising sailor: it's more bullet proof than plastic.
And steel boats are only bullet proof in hollywood films. It may be 'more bullet proof' but having been in war situations I'm not a fan of being 'a little bit shot'.
Knew a guy on a steel boat in Trini who had dents in the top sides from bullets after an incident off Venezuela![]()
His boat was definitely bullet proof in places, same boat was bashed up and down the quay in whatever that hurricane that went south was, Ivan was it?
Many hours of welding & bashing & painting before getting back to the anchorage, plastic boat would have been on the bottom within an hour.
So back to where we were really, steel is of little interest to almost everyone on here, but to the very few that venture farther and can use a welder & grinder & paintbrush it has some qualities head and shoulders above plastic.![]()
The trouble is that I completely agree with you. I’ve sailed thousands of miles on steel boats plus all the time I’ve spent on and under the sea on rather bigger steel ships and boats.
It’s the stupidly xenophobic utterings that I jib against. Steel is not the panacea against all our problems but is one option in the boat builders and designers available materials.
I think its the way that Brent thinks steel's good qualities trump all others options for boat building that's the real issue along with his idea that all the problems associated with steel are easily solved (they most certainly aren't!)
I now understand why this chap has not been banned. He is the unfortunate figure of fun for thousands and does not even realise it. That is a shame for him, and for everyone else, as his obvious experience and expertise is lost in his comedic ranting.
I am not a boatbuilding expert, but I know just about all there is to know about steel and fabrication. I know about issues with corrosion and fatigue that are near impossible to broach in land based vehicles and structures without constant maintenance, and even then nothing is forever. I love the idea of a metal boat, but I could not be doing with the reality of having to have the whole interior removeable to be able to inspect and maintain the hull, and all the work just to keep it from turning into a colander. Then again, I am a relative novice sailor, and not considering ocean voyages. We are however dead set on a liveaboard as soon as the last of our children have flown the nest. That will be plastic.
Incidentally, as part of our daily lives, and by way of experiment, my wife and I have abandoned the house, and we live in a large STEEL shed complex at the bottom of our garden. we have a log burner, and hot water from it's back boiler, and almost everything runs off 12v and an invertor. We are still properly sorting things like insulation. It is very hot in the summer, and very cold in the winter - the log burner heats it fine, but was very greedy. The only way to make it efficient was to insulate fully the whole building, walls and ceilings. This made a huge difference, and got rid of condensation. I imagine you would have to do the same on a steel boat - That is where my worries come in too. Doubtless Mr Swain you have a magic solution which might be interesting to hear if only you could moderate your tone and present your arguments as your point of view based upon experience, and not a negative defensive rant wrapped up in insults.
I STARTED READING THROUGH THIS THREAD FOR GENUINE REASONS AS LIVING ABOARD IS A LONG TERM GOAL FOR US. Why not use your experience to help ? I might be the Solent Clown, but it seems you are the man running his own circus. Instead of being the ringmaster of chaos, why not just calm down a bit my brother from across the pond. Sailing is a common interest, so why not show some common courtesy, and most of all, some common sense.
By the way, have you ever made a steel dinghy?
