Steam at WOT
RJJ
14 Aug 2009
Hi folks
Her engine otherwise starting and running perfectly, but a small amount of steam was noted at wide-open-throttle, on one of the slightly cool days recently. Nothing at cruising revs (2200).
Based on the following Steam out of exhaust
...it doesn't strike me as a matter of concern?
A slightly odd one in that we were on a seatrial as I am selling the boat. I don't wish to treat the buyer unreasonably but nor do I want to accept there's a significant problem...if there isn't.
He also noted there were bubbles being drawn up the raw water inlet...I have always seen bubbles being drawn up the raw water inlet under water and assumed they are a combination of turbulence and the impeller working well (given no leaks at the seacock or any of the hose junctions/strainer).
He is getting an engineer to check it over, but I wanted the view here first. Thoughts welcome, thanks.
Engine is D2-55. I replaced the exhaust elbow 2 years ago, plus c.250 hours, so it really shouldn't be that. She was relaunched with a clear saildrive leg the day before the seatrial.
dankilb
23 Jan 2008
Strange thing to comment on, IMO - that’s one of the ways I know ours is working (if my head’s in the engine compartment and I can’t be bothered to climb out and check the exhaust!)
(… that’s assuming he means the strainer? We also have a section of clear hose in the siphon loop and that normally runs bubble free, but if it didn’t - and wasn’t leaking water - I’d still think nowt of it)
  • Like
Reactions: RJJ
RJJ
14 Aug 2009
Mmm....not sure if he meant the siphon loop....but I agree, I am comfortable with bubbles in the water flow. if there's plenty of water at the exhaust and the alarm isn't going off, and no steam at cruising revs....I am struggling to see the concern.
Refueler
13 Sep 2008
Far away from hooray henrys
Is it really steam implying large amount or just the small wafts that generate from the warmer manifold at higher revs ??
My exhaust always has some 'wafts' of white vapour once you increase out of mid throttle.
This is at about 40% throttle .....
Yes I have a large water volume passes through my system - I have inlet full open instead of controlling flow as manual advises. Reason being that I do not wish to risk running at higher than the RAW WATER advised temp. Running higher can cause RAW WATER to deposit salts and other in the cooling channels.
RJJ
14 Aug 2009
It's about the same as your photo.
. But at full whack after a minute or so. Nothing seen after 30 mins of cruising revs.
My usual (hugely experienced) engine guru thinks it's fine, his view "you're not supposed to use WOT except to e.g. get out of the way of a ship, and then for a short time. If no overheat, and nothing seen at normal revs, it's not even nothing to worry about. It's nothing".
Thank you all for your responses. I am close to 100pc persuaded there is zero concern....anyone disagree?
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
The notorious steamers are Bukh DV20, probably a combination of elbow design and only having a 1/2 inch raw water supply seacock. They steam at only moderate revs but are renowned for their long life.
jwfrary
2 Dec 2010
Perfectly normal, cat c18s produce so much steam on thier exhausts in some installations, you can see the steam before the boat!
