Starter motor nearly catches fire
Was it actually being driven by electricity or did the pinion just stick in the on position and get driven by the engine? I'm guessing that it just stuck, in which case it's not an electrical issue so a fuse wouldn't blow.
Need a new starter motor.Why didn't the fuse blow.Starter motor was operated for 30mins with engine running after being lifted in.
Does it actually have a fuse at the engine starter battery ?
The wiring and fuse are rated for operating the starter, so no reason for the fuse to blow. The fact that the starter isn't rated for continuous use and over heated isn't something for the fuse to deal with.
Fuses only prevent fires in the wire they are designed to protect. Unfortunately in your situation that doesn't help.
Plenty of people have made this mistake, usually only once. I can't think of a clever way to prevent it unfortunately other than changing to a start button (which many boats have instead of a key). On our boat we'd have to physically hold the start button in to have this issue.
+1 for above. He doesn't actually say if his starter is U/S. Plus a starter motor, engaged and being driven by the engine, or running disengaged will draw very little current so wouldn't blow a fuse, even if there is one.
Thanks guys the solenoid on this pre engaged starter is knackered.The end of the rod that pushes against the actuator(?) had bits broken off.There was a smell of burning inside the boat which took some time to find the source of.
Lancashire Rotating Electricals will sort that out much cheaper than a new one including shipping.
My boat's Beta panel has a key, but it is spring-loaded to return to the neutral position from both pre-heat (held anticlockwise) and start (held clockwise); stop is a button.
I have experienced this also as I purchased a cheap generic spring loaded key switch to replace a starter button that had failed. Burned out both the starter and alternator on Yanmar. Needless to say I now have a button for cranking
The switch can still fail internally, so don't get too complacent!
Had a customers key switch stick in the stop position. The stop solenoid isn't rated for continuous use so got very hot, melted inside, shorted the wiring and the whole engine loom melted together, very close to catching fire. The circuit breaker didn't trip!
