crown22
Need a new starter motor.Why didn't the fuse blow.Starter motor was operated for 30mins with engine running after being lifted in.
Does it actually have a fuse at the engine starter battery ?Need a new starter motor.Why didn't the fuse blow.Starter motor was operated for 30mins with engine running after being lifted in.
+1 for above. He doesn't actually say if his starter is U/S. Plus a starter motor, engaged and being driven by the engine, or running disengaged will draw very little current so wouldn't blow a fuse, even if there is one.Does it actually have a fuse at the engine starter battery ?
The wiring and fuse are rated for operating the starter, so no reason for the fuse to blow. The fact that the starter isn't rated for continuous use and over heated isn't something for the fuse to deal with.
Lancashire Rotating Electricals will sort that out much cheaper than a new one including shipping.Thanks guys the solenoid on this pre engaged starter is knackered.The end of the rod that pushes against the actuator(?) had bits broken off.There was a smell of burning inside the boat which took some time to find the source of.
My boat's Beta panel has a key, but it is spring-loaded to return to the neutral position from both pre-heat (held anticlockwise) and start (held clockwise); stop is a button.Plenty of people have made this mistake, usually only once. I can't think of a clever way to prevent it unfortunately other than changing to a start button (which many boats have instead of a key). On our boat we'd have to physically hold the start button in to have this issue.
Had a customers key switch stick in the stop position. The stop solenoid isn't rated for continuous use so got very hot, melted inside, shorted the wiring and the whole engine loom melted together, very close to catching fire. The circuit breaker didn't trip!The switch can still fail internally, so don't get too complacent!
I never use WD40 on anything these days. What lube? Lock oil? 3-in-1 oil, silicon spray (mast-track) lube?Might be better to use a lube, WD40 will strip it bare and make it rust!
True, but at least the engine panel is inside the boat rather than directly exposed to the corrosive elements in the cockpit.The switch can still fail internally, so don't get too complacent!
