lustyd
Now that’s a thread of its own! You want the key clean or the lock smooth?I never use WD40 on anything these days. What lube? Lock oil? 3-in-1 oil, silicon spray (mast-track) lube?
I had the same starter motor issue 2 years ago. I have a starter button, no key switch, but the pinion stayed engaged with the ring gear. The starter, a gear reduction type, as many modern ones are, was being driven by the engine and started to smoke after just 2 minutes.Fuses only prevent fires in the wire they are designed to protect. Unfortunately in your situation that doesn't help.
Plenty of people have made this mistake, usually only once. I can't think of a clever way to prevent it unfortunately other than changing to a start button (which many boats have instead of a key). On our boat we'd have to physically hold the start button in to have this issue.
I have the same panel, but the key switch stuck in the start position, By the time I'd gone 300 yards to my mooring, the starter was fried.My boat's Beta panel has a key, but it is spring-loaded to return to the neutral position from both pre-heat (held anticlockwise) and start (held clockwise); stop is a button.
Would killing the 12v supply to the engine circuit (by simply flipping the isolator switch) not have disengaged the starter motor?I have the same panel, but the key switch stuck in the start position, By the time I'd gone 300 yards to my mooring, the starter was fried.
Starter motor burnt out happened to me too with a genuine Yanmar keyswitch. Keyswitch replaced with another Yanmar branded one. Some years later happened again. Now changed to pushbutton start, following suggestion by Yanmar dealer.I have experienced this also as I purchased a cheap generic spring loaded key switch to replace a starter button that had failed. Burned out both the starter and alternator on Yanmar. Needless to say I now have a button for cranking
