lustyd
Anyone with or considering Starlink might be interested that the service terms and packages have just changed.
Roam is now seemingly a single product, either 50GB for £50 or unlimited for £96/month. If you're away from your "service address" for over 2 months on a trip they will cut you off or you need to change your service address (easily in the website by the look of it). Use in motion, in coastal waters (up to 12NM) and international travel are all included.
Service addresses and all usage must be within Starlink "available" regions on their map, any use outside of this and you're cut off.
Use offshore is no longer possible with roam, instead you need to swap to a mobile priority plan (starting at £249/month for 50GB) but this can be for a single month while on passage.
Use in non-approved regions seems to be allowed using a mobile roam plan
These seem to be good changes and clear up a lot of the uncertainty we've been seeing recently with people being cut off. It might result in some paying a little more, but at it should be easier to understand and manage going forwards.
