Standing or Running Rigging
That's what I'm saying - is not a running back stay running rigging and a fixed back stay standing rigging? :)
The backstay I adjust is not a running backstay, but THE backstay. A running backstay's role is stop the mast falling down, even though it is only used on one tack or gybe - thus, because it supports the mast, not the sails - it is standing rigging. Running rigging is attached to a sail, standing rigging to a mast. (IMHO)
agreed
Chapman's Pilotage has an interesting take on the subject. It defines standing rigging as the structure required to support the sails - including the mast. It says that because modern boats have adjustable standing rigging - backstay adjuster, for example - "the line between standing and running rigging is becoming blurred".
I'll go with standing rigging attaches to the mast, running rigging attaches to the sails.
What does that make a topping lift, though?
Topping lift is running rigging, it only passes thro a block on the mast (like a halliard) & does not fasten to or support the mast. On a square rigger, the booms/ yards are raised & lowered with running rigging to reef or stow sails.
But many smaller boats have a topping lift attached to the masthead and adjusted at the end of the boom. Still, I'd always think of the topping lift as running rigging, even though it supports a spar and not a sail.
My boat is 38' and I have a wire topping lift attached to the mast with a block and halyard on the boom end that is led back to the cockpit - a similar combination of wire, rope and blocks to some running back stays in fact :cool:
