Stanchion bases
ccscott49
7 Sep 2001
OK, you knowledgeable lot. I need 8 bases for stanchions, in stainless steel, with 4 mounting holes, maybe 2 would do! but the need to be the type that are side mounted as on a passerelle, not bottom mounted. Any ideas?
Bajansailor
27 Dec 2004
Marine Surveyor in Barbados
If the stanchions are also S/S, could you have plates welded directly to the sides of the stanchions?
All else being equal, this form of attachment should be stronger than having the end of the stanchion welded to a plate (or in a socket type base).
All of the RNLI offshore lifeboats have these type of stanchions, where the bases are then through bolted to the toe rail / bulwark. Much better (I think) than bolting vertically through the deck.
ccscott49
7 Sep 2001
Yep, Thanks, basically what I'm after, but at that price, I will get them made in stainless. But thanks for your input, wasnt sure I was describing them properly now I know I am!
