SSB Question
ccscott49
7 Sep 2001
Somebody metioned a dipole doesnt need an earth plate on the set, would a triatic stay on a ketch do for that purpose and could that be tuned with an ATU, or do I need to have it exactly the right length? Taking into consideration I would only be using marine frequencies.
snowleopard
Oxford
other antennas
we have an unstayed rig so use a whip antenna (7.5m long, quite a beastie)
if you contact Icom they will sent you a leaflet on earthing. the essential is to have a strip connecting the ATU and ground plate. the sintered bronze plate is ideal if you don't have a metal hull. professionals use 4-5" wide strip. i get by with 2".
my tx power is adequate but not as good as some, don't know if it is the whip, narrow strip or something else entirely.
davidbains
15 Nov 2002
Re: other antennas
Snowleopard, interested you're using the motor boat solution of a 23ft whip. You used to see them advertised, where did you get yours?
Roberto suggests you can do the same with a fishing rod. I wonder what the max length
of fishing rod is, I will have to go and ask!
Sintered plates are an expensive ground and how do you keep it free of fouling, I know you're
not supposed to use antifouling.
And finally what transceiver are you using. I've been tempted by an Icom 706.
It occurs to me that on a multi it's very easy to raise an inverted dipole from float end
cleats to the masthead. Although that would leave a long run of coax back down the mast,
to confuse the ATU.
