TRH
HI urgent help needed, A freind of mine has inherited a Spinnaker Snuffer. Description as follows: Consisits of flat spiral plastic spring, Approx 8'' Dia. (Length as per the height of spinnaker) Top fitting stainless ring 8'' dia with 3 arms at 120 degrees spacing to centre rod. Welded at each end to centre rod and there connected to plastic snuffer, the rods are bent to form rectangle entrapping spiral. The stainless ring is free to rotate, except where saddle clip strikes spokes. Can anyone help with how this should be set up,or a makers name that might help, Or has anyone in the solent one that can be seen working. Many Thanks in anticipation from us both.
