Spade 80 anchor
Gunfleet
1 Jan 2002
Orwell
I've got one of these and took it apart for storage. Does anyone know the spec of the bolt and aero-type nut that holds it together because it's gorn (oh dear)
snowleopard
Oxford
much discussed of late as a result of an incident where the anchor supposedly came apart in use. the upshot is that you are advised to use a new nyloc nut every time you reassemble.
Gunfleet
1 Jan 2002
Orwell
Thanks Chris. It's the size that's bothering me because I dropped the bolt in the oggin. I don't want to guess the spec for the same reason people suggest using a new nyloc each time. i've tried pm-ing Alain Hylas but no reply. He's probably bobbing about on a wave somewhere.
bruce
26 May 2004
florida USA
if all else fails, you could carry it into a marine supply and hand fit a new bolt and nut, and get couple extras too.
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
I don't think the bolt is mission critical so long as it is marine grade SS and the right size for the hole. The nut should be a marine grade SS nyloc to fit the bolt - which should itself be long enough to ensure that at least two threads are showing through the nyloc.
- Nick
<hr width=100% size=1><font size=1><A target="_blank" HREF=http://www.bluemoment.com>http://www.bluemoment.com</A></font size=1>
hylas
6 Nov 2002
Canaries Islands
Yes.. I apologize.. I was crossing between Santos and Florianopolis..
The bolt is a 10 mm stainless steel (A-4 / 316 L) with a Nylock nut. If possible, drill a 3 mm hole in the extremity of the screw to fit a pin
If you have any further questions, please write to: hylas@free.fr
