Refueler
Prerviously I posted about weird size valves .... standard boston valve has thread diameter of 22mm ... but mine has 28.5mm.
After various pump up .. check ... see it deflate on its own .. I swapped valves over and found that the valves were not actually at fault .... and squirty soapy water found the tiny slit in the bow.
I have ordered glue as the glue in my kit has gone hard. While waiting - I decided to carefully Superglue the slit to make sure that was the only leak .... tiny drop - spray with kicker - slit sealed. I do not intend this as a permanent solution as water degrades CA glue. But enough to check it stays inflated. I will apply a patch over top of course.
In fact because its about centre line right on the bow - I may use a D ring patch and give myself a painter attachment - which it doesn't have.
The dinghy seats unclip, dinghy rolls up and seats / dinghy / pump all go in that carry bag. The oars are just a little too long but can stick out of bag OK.
The darker blue area is where the small hole was ...
It has no ply or air floor - so you do not want to stand up in it ! But I am wondering whether to adopt the same idea as my Avon and create ply slat floor ... here is the hypalon Avon ready for new slats for the Avon underneath ..
